Templates Not Appearing in Dialog for Host Entry
Implemented
Version 2019.2.13.0
I'm trying to figure out how to combine various session entries into a single entry to declutter my navigation tree view. I've created various templates using File -> Templates -> Templates for RDP and such. However, when I create a host entry, and then click the "Advanced" tab on the "General" view, then click the "Select Templates" button, the list is always empty; there are no templates to choose from.
Any ideas?
Thanks,
Kevan
All Comments (11)
Hello Kevan,
which datasource do you use?
Min
I'm using a Google Drive data source.
Thank you for your quick reply! I have been able to reproduce this issue and a ticket has been assigned to our engineering department on that matter.
I will inform you once I will have an update on that topic.
For further reference, the ticket number is RDMW-3923
James Lafleur
Our engineering department have implemented a few fixes in the latest version of RDM and it seems to have fixed this.
Would it be possible for you to try this version of RDM and see if this issue still occurs?
I would recommend trying it as a portable version in order to keep your current configuration untouched.
To do so, you will need to download the .zip file below, extract it's content in a newly created folder, enter your current serial and run the executable: https://remotedesktopmanager.com/home/thankyou/rdmbin
James Lafleur
The issue is still present in the latest version: 2019.2.18.0
Could you try RDM 2019.2.19.0? You can download this version here
https://remotedesktopmanager.com/home/download
As of version 2019.2.23.0, you will be able to use your templates in Host entries.
Jonathan Del Signore
Any idea when this version will be released?
RDM 2019.2.24.0 can be downloaded here
That's the enterprise edition. I'm using the free edition.
In that case, indeed, RDM Free 2019.2.21.0 does not contain the enhancement. You would need to wait the next release of RDM Free. Unfortunately, I cannot provide you any timeline for it's release for the moment.
