Let's say I need to get to a router somewhere but in order to get to it I need to first login to an RDP host via an RDP gateway, then from there RDP into another host, then from there SSH to another device and then finally SSH to the actual device I need to work on.
And maybe somewhere along the line I might need to initiate a VPN connection from within one of the RDP sessions (just to further confuse things). Could I use a macro for this or possibly by executing a command-line script after login?
Jumping from SSH host to another SSH host is achieved easily enough by using after login commands.
Could any of this be done by using sub-connections? I've seen the sub-connections option but am not really sure how (or why) they are used.
I figure that with all of the functions, features and options that RDM is capable of, at least some of this must be possible by applying some creative/lateral thinking, I just figured I would check first to see if this (or something similar) has already been achieved so as to not waste time re-inventing the wheel.
Thanks.
It's possible to accomplish this partially in RDM, but we cannot automate all the login process if you start an RDP, then RDP, then SSH and another SSH.
Using our Jump feature will allow you to open a RDP session and from that session "jump" into another RDP (or SSH) or any other remote session. If you are able to launch the second SSH session using the post login command, it may work, but it's the best we can do.
For more information on our jimp feature, please consult
https://help.remotedesktopmanager.com/overview_whatisrdmjump.htm
