Hi, I'm having issue trying to figure out how I can authenticate with the application using PS without interact with the login interface.
What I am trying to achieve is to delete inactive/deteled AD users from RDM database and this is part of our powershell leaver process.
What I have tried so far is below:
1)
Import-Module "${env:ProgramFiles(x86)}\Devolutions\Remote Desktop Manager\RemoteDesktopManager.PowerShellModule.psd1"
Get-RDMSession - (This prompts me the application login interface, insert admin username and password)
2)
$pass = ConvertTo-SecureString "mypassword" -AsPlainText -Force
Set-RDMCurrentDataSource -ID x-x-x-x-x -Username Administrator -Password $pass
Update-RDMUI
Get-RDMSession
In second scenario after I have used Set-RDMCurrentDataSource and then perform Get-RDMSession the cmdlet returns nothing.
When I use : Get-RDMUser and it returns WARNING: Your connection is not ready
Thanks
Ket
We are unable to reproduce this issue. In order to help you troubleshooting this issue, here are some questions about your RDM configuration.
1- What RDM version are you using?
2- What data source type are you connected to? If it's Devolutions Password Server, what version are you using?
3- Does the data source you want to connect to is the only data source configured in your RDM?
Érica Poirier
