how can i embed my Dameware Mini Remote Control (Version 12.1) in RDM (Version 2019.1.41)?
At the moment i get alwas a separate window of Dameware. Thanks
Unfortunately, it's not possible to launch Dameware session in embedded mode because Dameware doesn't offer us a proper API to accomplish this.
This is why it's only possible to open this type of session in external mode.
But my colleagues can double click on the computername and damewere open the session embedded in RDM. See Screenshot below.
Hello Thomas,
thats interesting! :\:
Is it possible that your colleagues are local Admins on the windows system? (And therefore they execute RDM with Admin rights) ?
Min
Are you using the same RDM version as your colleagues?
Are you running the same Dameware version as your colleagues?
Is TeamViewer installed on your computer as well? If yes, maybe you can try the solution proposed below
https://help.remotedesktopmanager.com/troubleshooting_putty.htm
