Resolved
layout view problems
In the print screens you can see that the line are not correctly displayed.
A layout reset didn't solve the problem.
I'v use version 2019.1.41.0 on a test machine and on the production machine I've version 14.1.3.0 on both the problem is there.
Can I get some help me to solve this problem.
All Comments (25)
Could you try deleting the .lyt files in %localappdata%\Devolutions\RemoteDesktopManager and then restart RDM?
David Grandolfo
deleting the .lyt files in %localappdata%\Devolutions\RemoteDesktopManager didn't solve it even when I delete everything in %localappdata%\Devolutions\RemoteDesktopManager
Are you using a HDPI monitor?
yes I use a hdpi monitor
Could you go in File -> Options -> User Interface and try to check/uncheck the Disable display scaling on high dpi settings option.
Let us know if that help.
It was unchecked so I checked the option but the problem is still there
What your Windows display scaling setting looks like?
Ls,
The Windows display scaling setting is set on 100% when I change it to 125% I don't have any problems
Is it OK to use this scaling setting?
Yes if I change the scaling settings then there are no problems
