Beyond Trust Password Safe connection type - Dashboard does not function
Resolved
When using the Beyond Trust Password Safe connection type, the Dashboard is not functional. i.e. it runs these tasks (Ping, Services, Computer Management, etc) against the Beyond Trust server and not against the intended target server.
All Comments (5)
Our BeyondTrust server is currently unavailable because we are waiting new license from their end. When it will be back on track, it would be possible for us to test this behavior and get back to you.
Sorry for the delay.
Thanks Jean-Francois.
Please keep in mind that if you have an existing BT connection in any of your RDM clients you should be able to see this behavior without the presence of a functional BT server. i.e. if you use Ping or some other function from the Dashboard it will not run that against the target server.
I see the feature you are using, but I'm not sure if we can run these features on the Beyond trust target machine (System).
If it's the case, we will have to ask Beyond Trust API for the host information.
I opened a ticket with the engineering department for a feature request.
David Grandolfo
I understand but when you add a BT entry in RDM, you do have the target machine value in the RDM connection properties.
We will confirm this information, but I'm not sure if the System name is the BT account name instead of being the DNS/IP.
We will test it and come back to you.
David Grandolfo
