SSH shell - 'Ctrl + Arrow' to move cursor word-by-word
Is is possible to enable the 'Ctrl + Arrow key' keyboard shortcut for SSH sessions to move the cursor word-by-word instead of letter-by-letter?
It used to be possible with the deprecated SSH session, where we could replace the PuTTY SSH application with KiTTY.
RDM version 14.1.3.0. Release notes does not seem to include this feature.
Thank you.
All Comments (5)
In RDM 14.1.3.0, our SSH Shell integration is based on Putty. If it's working in Putty, it should be possible to make it work in RDM.
You are using RDM 14.1.3.0 right?
Are enabling a specific option in Putty to make this work?
Hi Jeff,
It does not work in PuTTY but it does work in KiTTY - therefore it does not work in RDM, unless we replace the PuTTY .exe with KiTTY.
And we are using 14.1.3.0
