Implemented
TAG multi vault / datasource
I just found that TAGs are by vault but in some case we use the same TAG between each other. So that could be great have TAG in datasource layer so that way we don't need to recreate TAG in each vault.
Using RDM 2019.1.25 with SQL.
All Comments (12)
I will add this to our todo list. We could add a way to pre-configure the tags in the system settings.
Great so in that case only administrator will be able to add/delete tag from system settings right?
And a user will be able to add specific tag for a specific vault?
Exactly!
This will be available in RDM starting from version 2019.2.0.0. This version is planned for September/October.
You will be able to set a default list of tags in the system settings that will be available throughout all vaults, without needing a prior entry using that tag.
Great Thanks!
Just install 2019.2.19 this morning, the option is there yet, so it will be in a few next release?
If you are using DPS, it will only be available once version 2019.2.0.0 of DPS comes out. For SQL server or MySQL, it should already be available.
I'm using MSSQL, and I don't see anything about TAGs in system settings in RDM 2019.2.19.0.
It should be found in the system settings under Applications > Miscellaneous. Do you see this section?
Ok just found it now, I was using the search in system settings with tags word and but no result…
So now how I can replace a Tag I've set in a few vault, and I want to set the same tag for datasource without loosing the tag to all the entries? Exemple, I've set tag PROD to 800 entries in mutiple vault but now I want to populate the PROD tag to any vault without loosing all the relation with the tag PROD to all my 800 entries? Did I only need to create the same tag in the system settings and it will be merge?
When RDM creates the list of available tags in an entry, it adds up the list in the System Settings with the tags already used in the entries within the current vault. If there is two tags with the same name, it counts as the same tag, whether it comes from the System Settings or the entries.
In your case, from what I understand, adding the tag PROD to your System Settings will be what you want. It will not change anything with your already saved entries.
Thanks! I'll try this.
regards
