Safari Not Acknowledging Web Auto Login
Implemented
I've got a situation where RDM on Windows using the Chrome engine passes login credentials just fine, but when a user on Mac accesses the same website using the Safari engine, the exact same settings do not auto-login, or populate the form.
I can successfully use either id="login-box" or id="control-pad" in the Chrome engine. Neither of these seem to acknowledged in Safari.
The Mac is running High Sierra, Safari version 12.1.1.
The HTML Looks like this:
<body>
<iframe src="javascript:''" id="__gwt_historyFrame" tabindex="-1" style="position:absolute;width:0;height:0;border:0"></iframe>
<noscript>
<div style="width: 22em; position: absolute; left: 50%; margin-left: -11em; color: red; background-color: white; border: 1px solid red; padding: 4px; font-family: sans-serif">
Your web browser must have JavaScript enabled
in order for this application to display correctly.
</div>
</noscript>
<iframe src="javascript:&quot;&quot;" id="webapp" tabindex="-1" style="position: absolute; width: 0px; height: 0px; border: none; left: -1000px; top: -1000px;"></iframe>
<div aria-hidden="true" style="display: none;"></div>
<div id="body" class="body-container">
<div>
<div id="login-box">
<div style="margin: 60px;">
<div id="logo-pad"></div>
<div id="model-pad">
<div class="name">Phone Type</div>
<div class="desc">Phone Description</div>
</div>
<div id="control-pad">
<div class="control-row">
<div class="label">Username</div>
<div class="content"> <input type="text" class="gwt-TextBox"> </div>
</div>
<div class="label">Password</div>
<div class="content"> <input type="password" class="gwt-PasswordTextBox"> <button type="button" class="gwt-Button">Login</button> </div>
</div>
<div class="label">Language</div>
<div class="content"> <select class="gwt-ListBox"><option value="en">English</option><option value="es">Español</option></select></div>
</div>
</div>
<div id="footer-pad">
<div class="gwt-HTML">Copyright © Company Info</div>
</div>
</div>
</div>
</div>
</div>
</body>
Thanks for any help.
All Comments (17)
I've moved your post the the Mac forum. Thank you for sharing the HTML, this will be very helpful in reproducing the issue.
Xavier Fortin
Are we talking about a Web Browser session? If so, may I ask how you've configured the Login -> Html Control ID tab of you session?
Xavier Fortin
Hi Xavier,
Yes, this is Web Browser session, configured at attached. This actually works on a PC using the Chrome engine.
Thanks.
I might have an idea on what is the issue. I should have an answer and possibly a fix Monday.
Xavier Fortin
Awesome, thank you.
I've fixed the issue. I've made sure that the element class attribute was taken into account when searching for the fields and that div could be considered as form. I did the same changes for the buttons search, so you should be able to auto submit by putting "gwt-Button" in the "Login button ID" field of RDM. [ENTER] didn't seem to work.
Xavier Fortin
This is great news! Do you have a rough time frame on when the fix will be generally available?
Thanks!
I'm building a version at this very moment. You can expect it somewhere this week (if everything goes well).
Xavier Fortin
That is great. Xavier, thank you very much!
RDM and RDM Free 2019.1.6.0 have been released and contains the fix for this issue. Please tell me if you're having any other issues.
Xavier Fortin
