several problems with latest 2019.1.27.0
mephisto
Disabled
  • It keeps Connecting to Devolutions cloud, but I use local mariaDB
  • navigation panel is missing, then if you add it back and close RDM it will go missing next time RDM is opened
  • search not working
  • cannot type on search box
All Comments (5)
Could you try to disable the Automatically sign-in in File->Cloud?
After that you could try a Windows->Reset Layout?
mephisto
Disabled
Hi David,
I had to downgrade soon after I posted this as RDM was not usable without search for me.
No more prompts and search is back working
mephisto
Disabled
hi guys, still same issue with 2019.1.30.0 with devolutions online login even though I've only got local MS SQL and MariaDB databases.
https://imgur.com/ce3ymeq
Did you have the opportunity to try the steps that David described previously?
We suspect going to File -> Devolutions Account to disable the "Automatically sign-in at startup" option will stop the Devolutions Online Login prompts from appearing.
Gabriel Degrandpré
mephisto
Disabled
Hi Gabriel,
Thanks for that, indeed it worked.
