window filter - sometimes "enter" not establishe connection
When i open filter window and find connection I press "enter", the window disappears but does not establish a connection.
Sometimes need restart RDM and key "enter" working. I don't have checked option from attachment.
Coud you help me to resolve this problem, it is very annoying if you must use two-click from mouse to establish connection, when you try to use only keyboard shortcuts when working with ssh terminals.
All Comments (4)
Could you please open RDM and click on the "Magnet icon" in the bottom right corner? Doing so will deactivate the "Grab the keyboard output" feature and this might help with this issue.
If it persist, could you please tell me which version of RDM and what type of Data source you are currently using?
James Lafleur
