SSH Session through Citrix: Alt-Gr - Keys do not work
Hi all
I have RDP Manager installed on a Windows 10 Client.
I connect to the Client Desktop by using Citrix; then i start the RDP manager.
Then i use a stored SSH connection to connect to a Linux host.
I've disabled 'Application Keypad mode'.
My problem: Every character that can be typed in combination with Alt-GR does not work.
On my swiss-german keyboard i normally use Alt-Gr + 7 to type a pipe ( | ).
If i type Alt-Gr on the Windows 10 Client it works; but it does not within the SSH session.
Any ideas?
Best regards
Tom
All Comments (1)
The issue you reported has been resolved by our engineering department. The fix will be available in the next release of RDM.
Please consult our release notes to learn more about the latest improvements and bugs fixes in RDM - https://remotedesktopmanager.com/release-notes
David Grandolfo
Closed
