RDM an entry will not be saved (MS-SQL Data Soruce)
Hi there,
we are not able to edit and than save this changes (new hostname) on a SSH Session (built in SSH). We tried to Edit the "private Key" fro a key to non. will not be saved.
We are using an MS-SQL Server as data Source. The entry is not "checked out".
Even an edit on an duplicated entry will not save. But if i for example edit der Entry Name, this will be saved.
What do we do wrong ?
Gruß Michael
Could you post a screenshot of the properties of your SSH entry?
we are using the version 2019.1.21.0 (64Bit).
I am not able to reproduce your issue. I am able to edit the host, the credentials and I am able to set a public key as well as remove it.
That being said, are you able to post a small video of the issue so that I can try to reproduce internally.
On a side note, if you create a new entry, are you able to edit the entry as expected?
