Tabs are super-huge and horizontal scrolling is super-fast
on my 4K screen with a scaling of 200% the tabs in 2019.1 are way bigger than in the previous version resulting in less screen estate for my RDP sessions. Also it is impossible to scroll to the right by picking the navigation item and dragging it as for some reason the size of the tree view is enormous, so by moving the item just a little bit even the most expanded tree isn't visible anymore. I can still click the "right" button but this on the other side is super slow as in "not even moving one character at a time".
I hope you can fix this as I was looking forward to the announcement of UI changes, but at least for me things have gotten worse.
Regards, JK
All Comments (4)
What version exactly do you use? We have made a lot of HDPI fixes recently.
Hi David,
I just updated to the latest version (2019.1.21.0) and the tabs do indeed look better. The problem with scrolling horizontally is still there though.
Regards, JK
Are you able to create a small video of the scrolling issue?
Sure, I just did and will send it to you in a minute.
Regards, JK
