Quick Connect History in System Tray not working
Implemented
I've downloaded the latest free version of RDM, 2019.1.7.0 64-bit, running Windows 10. Previously, the Quick Connect on the System Tray was working perfectly for me, allowing me to click the Drop button to select the history. Now, it does not. The Quick Connect up on the Title Bar works just fine, but not when selecting from the System Tray.
I chatted with Tech Support today, who after a couple trials, suggested copying the settings out, uninstall RDM, delete Devolutions Folders, reboot, reinstall RDM, copy the settings back in, and see the results. They were the same. Quick Connect History works for me up in the Title Bar, but not in the System Tray.
Thoughts?
All Comments (2)
Could you post a print screen to guide me of the difference?
I've got it. I'm able to reproduce the problem. This should not be hard to fix.
