Right click - "copy host" on top
Implemented
Since our update to 20191.21.0 today we have the new "Feature" "copy host" on the top of the right-click dialog.
As i use always right click -> open session to avoid opening wrong connections this is really annoying... How to move this "copy host" away from the top? (Can't imagine that someone needs this in this place)
Thank you in advance,
Markus
All Comments (6)
This is not the expected behavior. We will fix this quickly.
Didn't expect that fast an answer ;-) Thanks a lot...
By the way, the new version is much faster in our enviroment,
Thank you again,
Markus
I'm glad that the new version is faster. What type of data source do you use? Is it SQL Server or DPS?
Microsoft SQL 2014, before the update it was sometimes realy slow to add or edit entries.
Markus
Just to let you know, we've fixed the "copy host" button being at the top. It should have been in the "clipboard" submenu. This will be available in 2019.1.22.0.
Thx!
