Pleasant Password Connection Problem
Hi guys,
i am able to configure the Pleasent Password Server Options with my Credentials. I am also able to link the entrys from pleasent password server to my connections. But when i start the connection it allways prompts for username and password.
This is what Debug show wenn i try to connect:
12:22:43.826706 Silent: System.Net.WebException: Method Not Allowed ---> System.Net.WebException: Der Remoteserver hat einen Fehler zurückgegeben: (405) Unzulässige Methode.
bei System.Net.WebClient.UploadDataInternal(Uri address, String method, Byte[] data, WebRequest& request)
bei System.Net.WebClient.UploadString(Uri address, String method, String data)
bei PassMan.Client.PassManWebClient.UploadString(String address, String method, String data)
--- Ende der internen Ausnahmestapelüberwachung ---
bei PassMan.Client.PassManClient.GetCredentialPassword(Guid id, String usageComment)
bei Devolutions.RemoteDesktopManager.Business.PleasantPasswordServerReader.GetCredentialPassword(String id)
Any Ideas? I have RDM 14.1.3.0, and pleasent server 6.4.12.0
All Comments (1)
Thank you for reporting this issue. As mentioned during our chat today, we suspect that this issue is caused by the fact that your Pleasant Password Server haven't been updated to the latest version.
If the issue persist, once the server has been updated, do not hesitate to contact us using the ticket you just submitted. For further reference, the ticket Devo-3124.
James Lafleur
