ssh problem after upddate to 2019.1.3.0
Implemented
After update to 2019.1.3.0 I can not establish ssh connection to Cisco ASR 9k
[2019-05-06 10:20:26] Setting up connection
[2019-05-06 10:20:26] Connecting as XXXX
[2019-05-06 10:20:27] Successfully authentified server
[2019-05-06 10:20:27] Starting password authentication
[2019-05-06 10:20:27] User authenticated successfuly by password
[2019-05-06 10:20:27] The server does not support language environment variable
[2019-05-06 10:20:27] Disconnecting
All Comments (10)
I will assign this to one of our dev. Do you use the SSH Rebex?
I am not sure, I created default ssh shell entry.
regareds
GZ
Hi
The environment variable error is a minor one and should not prevent the connection. There is something else going wrong so I will need more details to solve this problem. Could you activate "Verbose" in the "Advanced" tab, attempt the connection to your Cisco device, and post the resulting logs? This would be of great help to me.
Denis Vincent
Verbose Log:
[2019-05-06 16:58:58] Setting up connection
[2019-05-06 16:58:58] Connecting as XXXX
[2019-05-06 16:58:58] SSH banner: SSH-2.0-Cisco-2.0
[2019-05-06 16:58:58] Sending kex init
[2019-05-06 16:58:58] Received kex init
[2019-05-06 16:58:58] Selected algorithms: diffie-hellman-group14-sha1, ssh-rsa, aes128-cbc, aes128-cbc, hmac-sha1, hmac-sha1, none, none
[2019-05-06 16:58:58] Sending diffie-hellman kex init
[2019-05-06 16:58:58] Received diffie-hellman kex reply
[2019-05-06 16:58:58] Successfully authentified server
[2019-05-06 16:58:58] Sending new keys message
[2019-05-06 16:58:58] Sending userauth service request
[2019-05-06 16:58:58] Received new keys message
[2019-05-06 16:58:58] Received service accepted message
[2019-05-06 16:58:58] Sending userauth init request
[2019-05-06 16:58:58] Received userauth banner:
[2019-05-06 16:58:58] Received userauth failure: password
[2019-05-06 16:58:58] Starting password authentication
[2019-05-06 16:58:58] Sending userauth password request
[2019-05-06 16:58:59] Received userauth success
[2019-05-06 16:58:59] User authenticated successfuly by password
[2019-05-06 16:58:59] Sending session channel open request: 0/-
[2019-05-06 16:58:59] Received channel open confirmation: 0/1 WS 200000/200000 MPS 32000/32000
[2019-05-06 16:58:59] Sending pty request: 0/1 xterm
[2019-05-06 16:58:59] Received channel success: 0/1
[2019-05-06 16:58:59] Sending environment variable request: 0/1
[2019-05-06 16:58:59] Received channel failure: 0/1
[2019-05-06 16:58:59] The server does not support language environment variable
[2019-05-06 16:58:59] Sending shell request: 0/1
[2019-05-06 16:58:59] Sending channel close request: 0/1
[2019-05-06 16:58:59] Disconnecting
Thanks for the logs. I believe the charset negotiation is not welcomed by your device, so we will need to add a new setting to skip this step and you should be able to connect again (the previous implementation was not doing this step). I do not know when it will be available, another developper must complete some work to integrate this change into RDM, but it should be soon.
Denis Vincent
We've implemented the changes internally in RDM. This will be available in the next update, 2019.1.19.0.
We've also updated RDM Free 2019.1.3.0 to contain this change. You can reinstall the executable or download the zip file to try out the fix.
what do I need to change in session or global configuration to get it working ?
after reinstall prblem still exists.
regards
Sorry for the lack of information. We've added a new option in the advanced tab called "skip environment variable setup". Checking the option should fix your issue. This option is available in RDM Free 2019.1.4.0.
Thannk you for quick fix. Ssh to cisco ASR 9k works.
Grzegorz Zaworski
