In response to DEVO-2978 please add a Single Sign On experience for Azure AD joined devices connecting to a RDM database in Azure SQL.
I've read over your support ticket and have a few questions for you.
Can you please try and test with SSMS (SQL Server Management Studio) available here: https://docs.microsoft.com/en-us/sql/ssms/download-sql-server-management-studio-ssms
If it works with SSMS it should work with RDM. Note: we are not setup to test this exact scenario so we are going at it blind but according the documentation we are "doing it correctly".
Try to connect like this:
You may need to set the database name here for it work:
Does that work? If so, you are configured correctly now we need to figure out what the deal is with RDM. Now in RDM, double-check that you have selected "SQL Azure" & "Active Directory Integrated" and try to connect.
Still getting the same error as the one you mentioned in the support ticket? Can you please post the details of the error so that I can investigate further?
Stéfane Lavergne
