Changing domain by using Web protocol handler
b03
Disabled
Hi!
If I understand the Web protocol handler information page correctly, it should be possible to pass a custom domain to a session, right? In a URL like this?
rdm://open?DataSource=XXXXXX&Repository=XXXXXXXXXXX&Session=XXXXXXXXXXX&Domain=XXXXX
Is it possible to get this domain in a variable? I don't know where to find this custom Domain I'm passing. Should I reconfigure the 'Override Domain' section under Advanced?
I'd like to use this custom domain in a variable for use in the Post Login..
Thanks!
Where is the custom domain information's is saved exactly? At the folder level?
b03
Disabled
Hi Jeff,
well, to be honest, I don't know where it's being saved.. All I read was that I should be able to pass a custom Domain in an rdm:// URL, what I need to know is how that's being saved?
With this URL I'm trying to open an SSH session, I would like to use the domain passed in the Post Login feature.
So not sure how to answer your question..
Boudewijn
There's no variable that can be used to get an information in the Post Login feature.
What you can try, is to save the domain in the Information section of the session.
