Start RDP Sessions from Favorites Navigation
Implemented
Hi
Unfortunately I did not find anything in the search or searched incorrectly
We have illustrated the accesses of our departments in 5 Repository.
From all Repository I have put RDP connections together favorites.
If i double-click in the favorites Navigation on the RDP session, I will only be navigated to the corresponding entry in the Repository and can then open the connection.
Since we have a lot of customer data in the vaults, it takes up to 10 seconds to switch between the vaults. (But that's another problem.)
Is it possible to start RDP connections directly via the Favorites Navigations?
Thanks
Simon
All Comments (22)
If you are in the same repository as the session in the favorite, the session will start. If not, indeed, the session will only be selected in the repository.
I will move your post in the feature request section and contact our engineering department to see if something can be done regarding this.
Hi Jean-Francois
Thanks for the feedback.
We will wait and see if the feature request can be implemented.
best regards
Simon
The improvement has been made as requested and this should be available in the next release of RDM Beta
When the next beta will be available, it would be possible for you to download it from here https://remotedesktopmanager.com/home/download#Beta
Hi Jean-Francois
Nice to hear it.
Thank you very much for the excellent support.
Best regards
Simon
Hi
Has this already been implemented in version 2019.1.21?
Currently it is not yet possible to start the connections in other Vaults "directly" via the favorites.
There is currently the possibility "Select and Open"
When connecting to a favorite Server, the focus changes directly to the corresponding Vault and marks the server to be started.
After that you have to switch back to your favorites to start the next server.
That's not so cool.
Is it not possible to start the servers in the favorites without leaving the favorites window?
Let me verify with our engineering department and get back to you.
FYI
Maybe it's because we use DPS and therefore not all features are supported.
I have installed version 14.1.3 again and have the 2019.1.21 version no longer available.
This means that I can no longer carry out any tests at the moment.
https://forum.devolutions.net/topic31856-no-database-upgrade-after-update-to-.aspx
I had a discussion with our engineering department and it would be possible for us to add a new option to keep the Favorites section selected when opening a session from another repository. What do you think?
Hi Jean-Francois
Such an option would be very helpful to us.
We have a lot of objects in our favorites and this solution would make it much easier to start from the favorites window if the focus doesn't always change.
Excellent!
An improvement ticket has been opened. The ticket number is RDMW-2806.
Hi Jean-Francois
Do you have any news regarding this request?
We updated our DPS and RDM to the latest Version but when we double-click an RDP Session in the favorites Navigation he's still switching to the corresponding Repository.
There is now the possibility to select "select and open", but the view changes back to the corresponding repository.
Is there an option in the settings for this or can you please look at it again?
best regards
Simon
As I can see, the ticket opened to our engineering department is still open.
I will make a followup with them and get back to you.
The favorites tab will now stay open when double-clicking an entry. This change will take effect in the next beta version.
Jonathan Del Signore
Hi Jonathan
I have tested the latest beta and the connections via the favorites tab now work as desired.
Thank you very much.
Best regards
Simon
Hi together
Is it possible that this function is no longer included in the current release or is this function hidden in the options?
At the moment I have installed the version 2020.1.3.0 and on another client the version 2019.2.24.
If a server is selected in the favorites, the view switches back to the repository of the server and only then opens the session.
In the favorites are only the actions "Select and Open" and "Select Entry in Navigation Pane" available
Best regards
Simon
It always been this way. We need to switch to the entry vault if it's not the selected vault. You should see all the actions if the entry is in the current vault.
Do you mean that it no longer keep the favorite tab selected?
Hi David
I'm pretty sure it wasn't like that before.
See the post above from Jonathan.
I tested it months ago and it worked correctly without changing the view from the favorite pane
You're right about the view it should keep it. I've just tested it and it does keep the view for me. Could you try the latest beta?
I have now installed the latest beta version (2020.1.8.0)and DPS 2019.2.12.0
Unfortunately it still changes the view when I start a session from another repository
Is there perhaps a setting in the options that does this?
I will ask our QA to try to reproduce the issue.
I now have the version completely uninstalled and freshly installed with a clean config file and now it seems to keep the favorites view when starting a server from another repository.
I'll keep watching this. But for now, you don't have to do anything
Best regards
Simon
