Load from inventory regardless of entry type
Implemented
rotem
Disabled
Please add the feature to read the remote machine Inventory (WMI) with "Load from inventory" on the Information screen regardless of the entry type,
i use different tools to connect to remote machines and i know this feature is limited only when using RDP,
for example: i cannot create a computer record with Dameware Remote mini (or VNC/etc) and also have the inventory for reference, the RDP is not used as a support tool to workstations on many companies and adding this type only for reference is prune to be clicked by mistake and add extra information on the database that is not required.
Thanks,
Rotem
This should work for VNC. I will fix it for Dameware. Do you have any other types which does not work?
rotem
Disabled
i currently do not have more types,
when this fix will be applied ?
Rotem
What RDM version do you have now? It should already be fixed in the latest.
