variable $PASSWORD$ does not work if password itself ends with $-sign
I have a password that ends with a dollar sign.
If I then use the variable $PASSWORD$ it won't work, this means instead of the password itself it uses the word $PASSWORD$.
If I change the password so that it does not ends with a dollar-sign it works fine.
Conclusion; I cannot ue my password.
All Comments (9)
Which version of RDM are you using?
And could you detail in which scenario the $PASSWORD$ variable does not resolve?
David Grandolfo
I'm evaluating the Free edition 5.1.3.0 64bit.
Just take a Command line item (External Application)
Fill in a password that ends with a $ in the password field under the tab Host and Credentials.
(I also filled in the Host and Username...)
Under the general tab, under arguments I used -addr $HOST$ -name $USERNAME$ -password $PASSWORD$
This works fine if the password itself does not ends with a $
If the password ends with a $, then the translation is not done and then takes the word $PASSWORD$ instead of the content of that field.
Unfortunately I'm not able to reproduce the issue. Could you look at my steps if they are similar as yours.
The entry configuration:
I use parrot.bat script which shows the arguments.
The script contains :
@echo off
echo.
echo.
echo Username and Password are: %*
echo.
echo.
pause
Under Security, I enable Allow password in variable.
When I run it the result is:
Is it possible that a combination of special character could cause the issue?
Which other special characters have you?
David Grandolfo
I fill in Host: test1, in Username: test2 and in password: test3
I use in arguments : -addr $HOST$ -name $PASSWORD$
Result: Host shows test1 (is ok) Username shows $PASSWORD$ (not ok)
I use, for testing purposes, the -name field to show the content (password field is invisible)
Now, it completely won't work? Even without 4-sign?
See attachments.
In the property of the entry, under Security, does allow password in variable is checked?
David Grandolfo
Yes I forgot this one. (Therefore it even didn't work at all.)
But this weekend I'm sure I tested on a item and it did not worked with the dollar and worked fine without one.
I can't find it anymore... Sorry.
Just to confirm is the issue still there or with a new entry, it works?
David Grandolfo
Yes,
It works fine now.
Thanks.
Thanks, I'm glad that it works fine.
David Grandolfo
