Customize format/colour for active sessions
In the left navigation tree pane, I have a bunch of RDP entries. If I'm connected to them, the entry is bolded. I want to change the format of the RDP entries that I am actively connected to, perhaps a different colour or underline.
I know you can customize this PER entry here using the "Fore color" setting:
But I don't want to do this per entry. I want to set a default that applies to all entries, including new ones that I create in the future.
I'm always using the latest beta RDM x64 version.
Local data source.
All Comments (4)
Do you mean when it's connected, you can to customize the look?
Yes.
Basically, I have 1000+ entries in the navigation tree on the left. I want to easily identify what entry is currently active / focused. So if I am currently viewing the session entry "RDP Session 1", then I want this to be highlighted in the navigation tree on the left.
Local data source.
Thank you
Any updates on this please?
Local data source.
