Openvpn credentials in upper case instead of lower case
Resolved
sometimes the automatic insertion of the vpn credentials does not respect the upper / lower case
Thank you
I need further information to try to reproduce the issue.
Which version of RDM are you using?
Which version of OpenVPN is currently install?
Which version of OpenVPN addon (tools - add-on manager) is install?
Is the issue when Caps lock is enable on the keyboard?
David Grandolfo
Actually I had the CAPSLOCK enabled
Thank you
We have been able to reproduce your issue and a ticket has been submitted to our engineering department.
David Grandolfo
