Possible improvements for Wayk Now integration
Implemented
we actually use Wayk Now 3.0.3 and RDM 14.1.3.0
  • when you're connecting to a Client, we get every time scrollbars at the bottom and at the right side - it's not very comfortable - at the moment we choose every time => Input => Zoom out to get a "full screen" without the scrollbars
  • If you're use "Prompt for Permission" authentication you have to input the friendly name for each connection - a global option (like FIle => Options => Types => Wayk Now => Friendly Name) would be great.
So you set the Name once and can directly launch the Wayk Now connection without the additional prompt
What do you think?
Thanks!
Min
All Comments (7)
I will Hubert to check what can be done quickly.
Hey David!
Perfect, thanks! Maybe one additional point: Could the section for the Chat (Chat => Show Chat) be configured as a separate floating window? The screen section for the remote control would be bigger and you're able to move the chat window to a 2nd screen.
Thanks again! :)
Min
I will double check for the chat but I'm not sure if it's easy or not
Hello Min,
We've made a few changes internally that should be available for 14.1.4.0:
- Fixed sizing issue with the "auto" zoom mode.
- Fixed the "scaled" checkbox in the wayk entry settings which previously did nothing. It now sets the default mode for the "auto" zoom mode. This is what you need to use so that you don't have scrollbars.
- Added a default value for the friendlyname in File>Options>Types>Wayk. This doesn't remove the opening pop up since you still need to write a message to send to the remote host.
For the moment the chat still opens in the same window but we'll keep this request open since it would be useful. We could probably do the same with the file transfer list too. Let us know what you think once you can test it out and if there's any other improvements you'd like to see. :)
Hi Hubert,
perfect - thanks! Sure, I'll report soon ;)
Min
Hi Min,
You will be able to have a dockable floating chat window in the first release of 2020.2 of RDM Windows.
Jonathan Trépanier
Hi Jonathan,
thats awesome! Thanks for the update! 😉
Min
