Problems with OpenVPN Automatic authentication. Only some parts of username/password is entered
Implemented
I'm trying to implement the OpenVPN addon in our RDM v. 14.1.1.0, so far without luck...
I'm running OpenVPN GUI v. 11.9.0.0.
I've attached screenshots of my configured entry. Those are here: https://www.dropbox.com/sh/61hzl3gc365cfff/AABRsOJb40kFnepapVW9bvp4a?dl=0
When launching the entry it starts the OpenVPN GUI just fine, the GUI then asks for username/password and RDM is sending something to the GUI, the problem is that only some of the characters are entered in the username/password fields, sometimes it enters one character in the username, sometimes four and sometimes all of it. Sometimes the password is left blank or partly filled, and sometimes it enters the password in the username field...
It seems that there's major problems with the "Automatic authentication" settings. Do you have a fix for this ?
I tried to delete the .ovpn file that RDM creates multiple times to clear the cached username etc, but anyway it is struggeling when writing the username/password to the OpenVPN GUI.
It could be because it is sending the characters before the OpenVPN User Authentication window is shown which ends in not all characters passed to the window. Is there a setting to tell RDM to wait for x seconds before trying to paste the credentials of the User Authentication window ?
Thanks in advance
Best regards
Joe
All Comments (33)
Hello Joe,
Thanks for contacting support, I know that many customers solve this issue by updating our OpenVPN Add-on to the latest version.
To update the add-on go to Tools -- Add-on Manager and update OpenVPN to 2.8.0.0.
Then restart RDM as administrator (elevated privileges) and test it again.
David Grandolfo
Hello David
I am already using add-on 2.8.0.0
I am also already running as administrator.
I got my colleague to test it too, he has the same problems as me.
I have similar problem. I have a problem with automatic filling of key password in OpenVPN addon. If I enable "automatic key password entry" and fill the password, the password doesn't fill full and the window stays opened. Then if I fill the password manually, the VPN is opened successfully. It's interesting that automatic authentication method by using username and password works fine. The pictures with configuration VPN and VPN login window without complete password are in an attachment. I also use add-on 2.8.0.0 and run RDM as administrator.
