Auto Refresh issue
For some reason RDM automatically refreshes its complete layout every minute or so. The anoing thing about this is when I scroll through the navigation pane and the refresh happens the selected entry in that pane gets the focus again. For example:
I selected entry number 5 and I scroll down to entry 60 and the refresh happens I'm back at entry number 5 and need to scroll down again.
I tried to find if this is refresh is some sort of setting but I cannot find it.
Jasper
Could you please check in File - Data Sources - Settings if the Auto refresh parameter has been set with a value different than 0?
Érica Poirier
Yup that's what I was looking for. It was set to 30 seconds.
Thanks a lot and another mistery is solved.
Thank you for your feedback and glad that this was the setting you were looking for.
Érica Poirier
