Chrome entries not opening anymore on 14.1.1.0 and W10 1809
mephisto
Disabled
Hey guys,
I'm having problems with RDM 14.1.1.0 not opening Chrome entries, it just halts and free RDM completely and needs to be forcibly closed down.
I downgraded from 14.1.1.0 to 13 as it needed a database upgrade to use the very latest and I could not upgrade it due to other people using the system. yesterday I upgraded the database to latest version and upgraded my client to 14 and now I cannot open Chrome tabs anymore.
I've already uninstalled and reinstalled chrome, same with RDM.
What else can be done?
What type of Data Source are you currently using?
Are you opening your Web Browser entries in Embedded or in External mode?
Also, does the same issue occurs if you change your "Web Browser" from Chrome to Firefox?
Furthermore, I forgot to mention that you could also go to File -> Options -> Types -> Web and check "Disable Rundll32.exe usage"
James Lafleur
Hi james,
I'm using SQL datasource, and as embeded browser tab in RDM. It happens with Chrome and Firefox, but not with IE, but who would use IE anyway...
I changed the dundll32.exe to disabled, now Chrome is back working.
Thanks for that!
Hello Mephisto,
You are more than welcome! I am glad to see that it is now working!
James Lafleur
