SSH Shell Post Login Commands not Working
steve10
Disabled
If I enter more than one command in the Post Login commands, only the last one is getting executed. I am running the free version. I had no issues running multiple commands when I was running version 4.x, I upgraded to 5.1.1.0 yesterday and that's when the problem started.
All Comments (4)
We have been able to reproduce the behavior on our side.
For reference, we have created ticket DEVO-1301 relating to this issue.
Best regards
Gabriel Degrandpré
any update on this, I notice that there is a change in 2019.2 where instead of a command it's asking for a tying macro, has anyone else noticed that?
The initial issue where only the last command of the Post-login was entered has indeed been resolved back in RDM 14.1.1.0. I completely forgot to mention it in this thread at the time, I apologize for that.
Regarding the Post login only having typing macros as an option in 2019.2, I can confirm that this is the same on my side. I would need to see with our engineering department why the change was made to include only typing macros. In the meantime, depending on your needs, the After Connect tab of the Events section does still support scripts and command lines.
Gabriel Degrandpré
Hello bild675,
I just got confirmation from our engineering department that although the Post login page has been changed, its features are still the same. The column is titled "Macro", but other commands can also be entered there like in previous versions. We plan on renaming the column to reflect this.
Gabriel Degrandpré
