AD users and computers missing features when run uder RDM
When running AD users and computers in RDM using the Command Line (External Application) and Private Vault Search because this is a shared environment then some advanced features in the AD users and computers are blocked like the ability to add remove delete and so on. Please add a feature to allow all proper functions to work when using the Command line application load.
All Comments (8)
I don't understand what you want exactly? Could you post a print screen of what is blocked?
Attached
Could it be possible that it's just because the cmd is not running elevated?
I have run as administrator checked.
Does RDM also run with the Elevated Privilege? What application do you launch from the command line?
Yes both run in elevated mode
%SystemRoot%\system32\dsa.msc
How do you send the credential to dsa.msc? It's not automatic if you don't use the runas.
This is a shared RDM environment using SQL server. Therefore, we use the private vault search.
