Is there any way to float 2 Navigation panes? Would like to copy and paste more easily between databases.
thank you,
There is no possibility to have two Navigation panes displayed in RDM at the same time.
The workaround is to open multiple RDMs on your machine. You will have to enable the Allow multiple instances option box in File - Options -Advanced - General.
Érica Poirier
This works for me, thank you!
Thank you for your feedback. Glad that this solution is suitable for you.
Érica Poirier
