RDP copy problems
i am used to the problem and it did not bother me enough to ask but now i have to copy lots of different texts in some rdp sessions.
Is there a way to prevent RDM to reconnect (the rdp session) nearly every time i copy something? (strg+c and gui)
Greetings
All Comments (2)
This is most likely a bug in the Legacy Engine of RDP. You can try changing to the Modern Engine. You can do this globally via the RDP Engine option in the RDM Preferences under the Session Type -> RDP tab in the General box.
Xavier Fortin
works like a charm! Thank you!
Greetings
Ends in 6 days
