move/delete/duplicate entry not working
when i move an entry in a different folder a copy of the entry is made.
when i delete the copy the original entry is deleted.
looks like the copy is some kind of "link"
when i create a duplicate entry and delete the duplication afterwards, the original entry is deleted (even if renamed before)
version 14.0.2.0, tested on 2 workstations.
All Comments (6)
What data source type are you connected to?
Érica Poirier
still mdb
I have good news. We have fixed a series of bugs (all related) with Access and this will be in the next minor update. Yours should also be fixed. I hope to release it later today.
great news!
Thx a lot, i'll start testing as soon as new version is available.
hello, 14.0.3.0 is out and has the fix for mdb.
Warning, if you delete one of the duplicates, both will be deleted. Since in v14.0.3.0 we treat {abcd1234-...} & abcd1234-... as the same ID.
As for new session created since 14.0.0.0 you will be ok you don't need to worry and change anything.
So your duplicates will need to be cleaned up properly to avoid data loss.
You have a few options. Make sure you backup your .mdf file.
1 - Open the database with MS Access and delete the sessions with "{ }" in the ID
2 - Export your sessions, delete the duplicates, import your sessions. Since the import will "distinct" the imported sessions, you will no longer have duplicates.
Let me know if you need assistance.
Alexandre Roy
Hello Alexandre, thx for infos!
Closed
