Database problems after upgrade
i can't connect to our datasource after upgrading the database scheme. RDM crashes right after trying to connect to the datasource. Cleaning the cache and creating a new data source does not help.
RDM 6.0.0.0
Error:
Unable to Connect to your Data Source
Fatal error encountered during command execution.
i can't click any button (e.g. details) because RDM hangs for good.
please help :)
greetings
All Comments (11)
Tried a manual database upgrade - after the upgrade we could connect again but suddenly after 5 minutes the error was back and RDM crashes right after starting again.
It was possible to fetch the error details:
MySql.Data.MySqlClient.MySqlException (0x80004005): Fatal error encountered during command execution. ---> MySql.Data.MySqlClient.MySqlException (0x80004005): Fatal error encountered attempting to read the resultset. ---> MySql.Data.MySqlClient.MySqlException (0x80004005): Reading from the stream has failed. ---> System.IO.EndOfStreamException: Attempted to read past the end of the stream.
at MySql.Data.MySqlClient.MySqlStream.ReadFully (System.IO.Stream stream, System.Byte[] buffer, System.Int32 offset, System.Int32 count) [0x00015] in <1add403c719d4eeeae437db5aa8f6c1a>:0
at MySql.Data.MySqlClient.MySqlStream.LoadPacket () [0x00076] in <1add403c719d4eeeae437db5aa8f6c1a>:0
at MySql.Data.MySqlClient.MySqlStream.LoadPacket () [0x000a5] in <1add403c719d4eeeae437db5aa8f6c1a>:0
at MySql.Data.MySqlClient.MySqlStream.ReadPacket () [0x00000] in <1add403c719d4eeeae437db5aa8f6c1a>:0
at MySql.Data.MySqlClient.NativeDriver.GetResult (System.Int32& affectedRow, System.Int32& insertedId) [0x0001e] in <1add403c719d4eeeae437db5aa8f6c1a>:0
at MySql.Data.MySqlClient.Driver.GetResult (System.Int32 statementId, System.Int32& affectedRows, System.Int32& insertedId) [0x00000] in <1add403c719d4eeeae437db5aa8f6c1a>:0
at MySql.Data.MySqlClient.Driver.NextResult (System.Int32 statementId, System.Boolean force) [0x00022] in <1add403c719d4eeeae437db5aa8f6c1a>:0
at MySql.Data.MySqlClient.MySqlDataReader.NextResult () [0x000d2] in <1add403c719d4eeeae437db5aa8f6c1a>:0
at MySql.Data.MySqlClient.MySqlDataReader.NextResult () [0x001f3] in <1add403c719d4eeeae437db5aa8f6c1a>:0
at MySql.Data.MySqlClient.MySqlCommand.ExecuteReader (System.Data.CommandBehavior behavior) [0x001ea] in <1add403c719d4eeeae437db5aa8f6c1a>:0
at MySql.Data.MySqlClient.MySqlCommand.ExecuteReader (System.Data.CommandBehavior behavior) [0x002ac] in <1add403c719d4eeeae437db5aa8f6c1a>:0
at MySql.Data.MySqlClient.MySqlCommand.ExecuteReader () [0x00000] in <1add403c719d4eeeae437db5aa8f6c1a>:0
at (wrapper remoting-invoke-with-check) MySql.Data.MySqlClient.MySqlCommand.ExecuteReader()
at MySql.Data.MySqlClient.Driver.ReportWarnings (MySql.Data.MySqlClient.MySqlConnection connection) [0x00019] in <1add403c719d4eeeae437db5aa8f6c1a>:0
at MySql.Data.MySqlClient.Driver.CloseQuery (MySql.Data.MySqlClient.MySqlConnection connection, System.Int32 statementId) [0x0000e] in <1add403c719d4eeeae437db5aa8f6c1a>:0
at MySql.Data.MySqlClient.MySqlCommand.Close (MySql.Data.MySqlClient.MySqlDataReader reader) [0x00053] in <1add403c719d4eeeae437db5aa8f6c1a>:0
at (wrapper remoting-invoke-with-check) MySql.Data.MySqlClient.MySqlCommand.Close(MySql.Data.MySqlClient.MySqlDataReader)
at MySql.Data.MySqlClient.MySqlDataReader.Close () [0x0008e] in <1add403c719d4eeeae437db5aa8f6c1a>:0
at System.Data.Common.DbDataReader.Dispose (System.Boolean disposing) [0x00003] in <bbe64cb6cb954b0c8bf8dbf03087621a>:0
at System.Data.Common.DbDataReader.Dispose () [0x00000] in <bbe64cb6cb954b0c8bf8dbf03087621a>:0
at A.c8bb832eaa4caed25b50caade71232a37.cc36fefaaceb5acfdf3c4a14f7813df4d () [0x00140] in <9cceae2923fd466e8cbe314df4acd410>:0
Thank you for contacting our support service. To better assist you, we require more information about the issue
What type of data source are you using? (File – My Data source information, use the "send to support" button.)
Is the connection still work for your colleagues or from another computer?
David Grandolfo
Hello again,
As soon as I post my question I saw your error. Could you send us the Database Schema of you MySQL database please?
Normally, under File -- Data source when you edit MySQL data source configuration you should see Email Schema to support.
Have you the option?
David Grandolfo
https://www.dropbox.com/s/81qjdi57ulnp5ns/Devolutions.RemoteDesktopManager.Mac.6.0.0.1540408097.dmg?dl=0
Could you also try this version when you get a chance?
Xavier Fortin
No worries - i can't send the schema to support, I think its because i'm not (can't) connect to the DB.
The Version from Mr. Fortin seems to be working! I will give it a proper testdrive today. (Do you still need the schema?)
Thank you both!
Greetings
Out of sync with server Error is back:
MySql.Data.MySqlClient.MySqlException (0x80004005): Out of sync with server
at MySql.Data.MySqlClient.NativeDriver.ReadOk (System.Boolean read) [0x00097] in <1add403c719d4eeeae437db5aa8f6c1a>:0
at MySql.Data.MySqlClient.NativeDriver.SetDatabase (System.String dbName) [0x0003c] in <1add403c719d4eeeae437db5aa8f6c1a>:0
at MySql.Data.MySqlClient.Driver.SetDatabase (System.String dbName) [0x00000] in <1add403c719d4eeeae437db5aa8f6c1a>:0
at MySql.Data.MySqlClient.MySqlConnection.ChangeDatabase (System.String databaseName) [0x00087] in <1add403c719d4eeeae437db5aa8f6c1a>:0
at MySql.Data.MySqlClient.MySqlConnection.Open () [0x0019d] in <1add403c719d4eeeae437db5aa8f6c1a>:0
at A.c8bb832eaa4caed25b50caade71232a37.cea9773bcf34f5a19ac6169d5f601a034 (System.String c3a7c71f30053a5a40fc3b4f66e72b871, System.Boolean c1b4a1fa885a8033610f52375d3643a7c) [0x00125] in <5550828c379a4180b5d5540eb56c73a4>:0
Full schema dump error:
Schema dump failed with error:
Value cannot be null.
Parameter name: value
Test Schema and Test Host are successful.
The schema error should be fixed. I'll release a patch soon.
As for the Out of sync error, we've found an similar issue on the MariaDB issue tracking service. You haven't mentioned it, but are you using MariaDB?
Xavier Fortin
thank you!
Oh, yes a colleague switched it to MariaDB and i forgot about it (Sorry, nice find). I tried it with the MariaDB connector but still get the same error. Should we switch back to MySQL?
Greetings
MariaDB connector error:
Well, it depends on your urgency.
Here is the issue in question: https://jira.mariadb.org/browse/MDEV-16308
You might want to follow it.
If the issue prevent you from working, it might be better for you to go back to MySQL, as I do not know when a fix will be made in MariaDB.
Xavier Fortin
Thank you for your help and identifying the issue!
We will wait until next week and see if there is any progress.
Thank you!
Greetings
