Hi everyone.
After upgrading to the latest version today, and upgrading the database, i'm have a wierd issue with my RDP manager.
Normaly i go to the navigation plane, and i type the folder name, but now i only get to type one caracter, and then it changes to the "Actions" buttons.
So.
- Open RDP Manager.
- Click in the "Navigation"
- Then the active field changes to "Actions".
Please assist, it is driving me nuts! :)
/Jens.
I did the same tests in local datasource, and it is the same.
(btw. we are using a SQL server as the datasource).
I was hesitant to run the "Reset layout", as i saw a lot of people having problems afterwards.
But i tried it anyway, and it is still the same.
+ I rebooted the computer.
+ Empty folders do not change to the "Actions" plane
When clicking a empty folder, i can navigate using they keyboard arrows, and use the search function again.
But as soon as i use the mouse again, it starts jumping to the actions plane again.
Could you post a print screen of what you mean?
Hi again.
When i mark "Test 2" (The BLACK circle) it jumps to "Open Session" (The Orange circle), so when i want to go back to "Test 1" using the keyboard, i'm not able to.
And i cant search for other entries in the list of folders and hosts.
The top part "Navigation" gets dark grey when i mark the entry, but turns light grey after 0,5 seconds, and marks the "Open session".
Oh, and by the way, my colleague is experiencing the exact same issue.
I'm investigating. I will let you know.
Thankyou.
Goodmorning David.
The problem seems to be solved in the new update from today.
It's back to normal.
I rebooted, and it is still OK. So the bug seems to be fixed. :)
