With over 4,000 servers I use the Filter Dialog a lot. One thing that catches me up is when a colleague refers to the Server by IP address. It would be great if I could enter the IP and have the Navigation page filter down the list of servers.
Thanks!
Is the IP address information saved in the Information section of the session?
If yes, you can search by IP in the filter by enabling this option
Awesome, thank you for this. Is there a way to make this the default setting for all users in a terminal server installation?
This information is saved in the RemoteDesktopManager.cfg file, which is your default.cfg file as per our documentation.
https://help.remotedesktopmanager.com/installation_terminalservices.htm
Once this option is enabled, just create a new default.cfg file to distribute this option to all your users.
