Password in variable not used in SSH Shell entry
I have a SSH Shell entry which logs on perfectly. Afterwards I need to execute the enable command followed by an enter key. The next command should be the password followed by an enter. This does not types the password but litteral $PASSWORD$. See the config of the entry in the screenshots.
Jasper
All Comments (2)
You need to set the Allow password in variable option on the Credential entry too.
Could you please try it out and let us know if it works?
Érica Poirier
You are absolutely right. Thanks Érica.
