Quick Connect session undock to wrong monitor
I'm currently on 13.9.10 x64.
My Quick Connect RDP template display setting is set to Embedded tab. Every now and then, I would undock the session to my secondary monitor and for the most part, it works. However, some of the Quick Connect sessions don't do this and undocks to the primary monitor instead (which is a smaller screen and I don't want to use that). I've noticed that if a Quick Connect session is RDP to a Server 2016 VM, then it will undock to primary screen. Otherwise, if it's 2012 R2, it'll undock to the secondary monitor.
I've also noticed that some VMs do not respect the "undock maximized" setting (configured in the Quick Connect RDP template). Some VMs would undock and not maximize, whereas some would and this is regardless of Server versions.
I'm always using the latest beta RDM x64 version.
Local data source.
All Comments (5)
Just to make sure I understand correctly, you launch a quick session in Embedded mode, then you un-dock it but it doesn't automatically go on your second screen?
Or do you use another template to launch the quick session in un-dock on your second monitor but it launches it on your primary monitor?
Best Regards,
Etienne Lord
Good question.
It's the first one - I launch a quick session in embedded mode, then undock and it stays on the small screen instead of my second larger screen.
The funny thing is, if I right click on the quick session in embedded mode, save the session and set the display to undock to my second screen, then running the saved session works as expected.
Local data source.
I suspect that we don't check the destination with the undock action like when it's the initial open. I will log this
Hi David,
Any updates on this one please?
Local data source.
Still on the todo list.
Closed
