I am trying to setup an RDP connection using keepass or thycotic stored credentials.
- When connecting directly the connection works perfectly using the credentials stored in keepass and thycotic.
- When seting up a RDP gateway the connection is prompting for the password.
Version 13.5.6.0
Cédric Jolivet
How the RD Gateway is configured in your RDP session? Could you post a screenshot of the Connection tab?
Does the RD Gateway use the same credential configured in the remote session to establish the connection?
Hi Jeff,
I attached the requested screenshot.
Cédric
Hi Jeff,
I found the solution. I will let you tell me if it is a bug or not ;-)
if the RDP connection is setup with display=external and the connection is open using the "open (embedded tab)" button then it works correctly I am not prompt for credentials, if I use the "Open (External)" button I am prompted for credentials
if the RDP connection is setup with display=embedded or undocked and the connection is open using the "open (embedded tab)" or "Open Session" button then it works correctly I am not prompt for credentials, if I use the "Open (External)" button I am prompted for credentials.
I tested it in another environment with the latest version 13.6.7 and the results are the same.
Is it a bug?
Best Regards
Cédric
It seems to be a bug with the Open External button.
I have opened a ticket and asked our QA department to try to reproduce this issue internally.
The ticket number is DEVO-598
I would like you to test something for us if possible.
Could you go in File -> Options -> Types -> RDP and check/uncheck the Use RDP Gateway generic credentials option to see if that help.
Hi Jeff,
check/uncheck this option does not change the result with the "Open External" button.
Cédric
Thank you for your feedback.
FYI - We are still waiting for our QA department to reproduce your issue.
