Enable inheritance for passwords for ssh devices
martin16
Disabled
it would be helpful if it is possible to add a password for a folder and select on a ssh device that the password from the containing folder is used for login. I have a dozen of devices wich are using the same password and always after a password change I need to touch every ssh device to change the password instead of changing the password stored on the folder.
Kind regards
Martin Spies
All Comments (1)
Hello Martin,
are you using the Enterprise or Free edition? In the Enterprise Edition the feature is already available.
Min
