rdesktop from android > click delay and long press doesn't produce right click
denywinarto
Disabled
Using it from note 8,
latest version, just instaleld it last night from playstore.
Sometimes i get click delay,
and long press doesn't trigger right click.
I read a post that double tap and click could do this, but it's same with the first issue,
sometimes after double tapping right click still wont show up/
All Comments (6)
As per title says
i get click delay,
and long press doesn't produce right click.
Latest version, just installed it last night
please delete this, not sure why but i get a bunch of strange characters on prev post so i had to create another topic/
We will try to recreate your issue.
I will let you know when we have news.
Mark Beausejour
By the way, do you use Remote Desktop Manager or rdesktop?
@david im using your remote desktop android app to connect to microsoft's rdesktop protocol.
The delay happens all the time. I had to tap several times sometimes.
Also IMO double tap + tab for right click is not very user friendly,
please bring back long press, its more convenient for one hand usage.
One hand usage is very important for cellphone users.
I cant double tap with one hand holding the phone.
Teamviewer, MS' android rdesktop and chrome iirc all use long press to trigger right click.
Other than these 2 bugs your app is on par with teamviewer so i hope you can fix these..
Just to make things clear, a double tap does not trigger a right click. A single tap with 2 fingers will trigger the right click.
You can also press the mouse icon on the toolbar, your next tap will trigger a right click. It is true, the user experience could be improved for phone users.
We will check what we can do to trigger the right click with a long press.
Concerning the delays that you are experiencing, we are not able to reproduce the problem on our side and haven't received any complaints related to rdp session delays. To help us out, can you try to connect to the same host from the same network and same device with the Microsoft RDP Android application? We would like to know if you are experiencing the same delays with Microsoft's application.
Nicolas Dufour
