X11 forward Display setting
since the putty support is deprecated we were trying moving to ssh shell. But got a big problem, most of our users were working on terminal-servers, every user has his own local display. In putty they were able to define one display X11 for all session, in ssh shell i can't find such support. It would be nice if you can add support for individual X11 Display forward under File -- Options -- Types -- SSH. Without this feature we can't really migrate, cause the actual rdm version got an annoying display problem with putty witch can't be fixed. (see ticket https://forum.devolutions.net/topic29813-using-putty-in-embedded-mode-last-line-not-full-visible.aspx?lastpage=1#post118030)
Thanks
Greetings
Steffen
All Comments (2)
Hello Steffen,
This shouldn't be difficult to do. We'll add this to our todo list and let you know once it's available. :)
The feature has been done internally. It will be available in version 13.6.4.0 of RDM enterprise.
The "enable X11 forwarding" checkbox will be replaced by a drop down with a "default" value. The default can be set in File>Options>Types>Terminal. I think this will work for your use-case.
Closed
