Documentation tab not visible in Offline Mode
Hi!
The Documentation tab is not visible in Offline Mode:
As soon as you switch to online mode, it appears:
Is this by design?
Kind regards,
Daniel
All Comments (6)
Indeed, the Documentation is not available in Offline mode because the information is saved in the database.
It is as you said by design.
Marc Beauséjour
Hi Mark,
and thank you for your answer. Everything is saved in the database, so why is the documentation treated differently and should not be available offline?
Thank you and kind regards,
Daniel
This would create a sizeable offline cache and might cause issues with performance.
Marc Beauséjour
OK, this definitely makes sense. A configurable option would be even better, I suppose. We are misusing the documentation feature for storing SSH public keys because I couldn't find a better place to store them together with the private key. So size wouldn't be a problem in our case.
Thank you very much for the clarification!
Kind regards,
Daniel
Hello Daniel,
sorry that I meddle, but could the Hinweis / Sichere Notiz session (as sub connection) fulfill the requirement?
Min
Hi Min!
Thank you for your suggestion. This way it isn't stored within one entry (it seems Private Keys don't support subconnections), but at least it is available offline. I think this will be the way to go for us.
Thanks once again and kind regards,
Daniel
