Double Click Command Line entry to open the connection.
dbrame
Disabled
Why is it on every other connection (at least all the other connection entries I have create) that you can double click it to open it up, but a Command Line entry I need to press the execute button on the dashboard? Not sure if this been mentioned before. IT seems like everyone other connection is meant to be double clicked to automatically open, yet this is not there for the command line entry.
Can it be set for a double click to execute a command line entry?
All Comments (4)
Indeed, you should be able to double-click to execute a command line session.
Which type of command line session have you used to create your session? Is it a blue icon or a green icon?
With the blue icon, you should be able to use the double-click to launch the session
https://help.remotedesktopmanager.com/sessions_commandline.htm
dbrame
Disabled
it is the green icon
If you create this type of entry instead, is it working as expected?
dbrame
Disabled
I did that yesterday. thanks for the pointer.
