Is it possible to auto reconnect RDP when it reboots ?
I would like to ask about if it is possible to auto reconnect RDP when the RDP reboots.
I am using remote desktop manager free version to working with one windows VPS I rent.
However, the windows vps reboots oftenly, so I have to check and reconnect with it very often.
Will there be any setting or function to let remote desktop manager auto reconnect if the vps reboots?
All Comments (4)
Indeed, this is possible using the Keep tab on disconnect feature
https://help.remotedesktopmanager.com/tipsandtricks_keeptabsopened.htm
Please note that this feature is available in the Free Edition of RDM as well.
The content of the link seems to be removed or perhaps changed to a new location?
Kind regards, Jesper
https://help.remotedesktopmanager.com/actions.html?q=keep+RDP
Scroll down to settings and it should show what you need.
Thanks
Iain
Thanks!
