Double click to open connection lost
I seem to have lost the ability to double click on connection in the tree to open the session. Any ideas where to look to resolve this?
Thanks
What version of RDM are you using?
Unless I'm mistaken, you seem to be experiencing the same issue that has been reported here;
https://forum.devolutions.net/topic28622-double-click-to-open-session-doesent-work-.aspx
Am I assuming correctly?
Marc Beauséjour
Yes 100% the same. Even to the point where double clicking a folder works but not for opening a session.
There will be a big update from the third party we use in the next version of RDM.
This could potentially resolve this but I cannot say for sure.
I can't give you a time frame for a release.
As David said in the other forum post, this is not an easy issue to fix.
Marc Beauséjour
