Set-RDMCurrentDataSource : Object reference error when starting PowerShell (RDM CmdLet)
Using:
Remote Desktop Manager Enterprise
13.5.6.0 64-bit
If I run RDM from one machine the PowerShell (RDM CmdLet) opens fine.
On a second machine the PowerShell (RDM CmdLet) opens but then displays the following error message:
Set-RDMCurrentDataSource : Object reference not set to an instance of an object.
At line:6 char:1
+ Set-RDMCurrentDataSource -ID "91c7xxxx-xxxx-xxxx-xxxx-xxxx3e30b83e"
+ CategoryInfo : NotSpecified: (:) [Set-RDMCurrentDataSource], NullReferenceException
+ FullyQualifiedErrorId : System.NullReferenceException,RemoteDesktopManager.PowerShellModule.SetRDMCurrentDatasourceCommand
Both installations are connected to the same shared cloud database with the same user and account.
Both machines running Windows 10 Pro 64-bit.
That ID doesn't match the Data Source ID found under File > My Data Source Information.
Running
Update-RDMUI
produces the following error message:
Update-RDMUI : Object reference not set to an instance of an object.
At line:1 char:1
+ Update-RDMUI
+ CategoryInfo : NotSpecified: (:) [Update-RDMUI], NullReferenceException
+ FullyQualifiedErrorId : System.NullReferenceException,RemoteDesktopManager.PowerShellModule.UpdateRDMUICommand
Am I missing something?
Jamie
If you try to do a full refresh with CTRL+F5, then are you able to open the PowerShell (RDM Cmdlet)?
If not, could you please try to go in File - Data Sources and create a new cloud data source with the same credentials to see if you will be able to open it from this new data source?
Érica Poirier
Hi Érica,
Full refresh CTRL+F5 didn't do the trick but re-creating the Data Source seems to have taken care of the issue!
Thank you.
Jamie
Thank you for your feedback! Glad that re-creating the data source resolves the issue.
Érica Poirier
