Faulting module path: msmpeg2vdec.dll
Upgraded to Remote Desktop Manager Free 4.6.0.0. 64 bit yesterday, since then the application has been crashing regularly (closes without an error or warning).
In the application log are 2 entries:
Application: RemoteDesktopManagerFree.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: exception code c0000005, exception address 00007FFB3D7EFBD0
Stack:
Faulting application name: RemoteDesktopManagerFree.exe, version: 4.6.0.0, time stamp: 0x5b0db109
Faulting module name: msmpeg2vdec.dll_unloaded, version: 10.0.17134.1, time stamp: 0x31260b52
Exception code: 0xc0000005
Fault offset: 0x000000000015fbd0
Faulting process ID: 0x54a8
Faulting application start time: 0x01d3fdf3b39b8b71
Faulting application path: C:\Program Files (x86)\Devolutions\Remote Desktop Manager Free\RemoteDesktopManagerFree.exe
Report ID: 987f2dfd-986a-475f-a5ea-92a912d36335
Faulting package full name:
Faulting package-relative application ID:
Running Windows 10 1803
All Comments (5)
We have received emails from a few customers back in December 2017 and they mentioned that RDM crashed since they have updated their Windows 10 to Windows 10 1709. As I can see, you are on 1803.
The faulting module was the same as you; msmpeg2vdec.dll_unloaded.
We found a potential fix from Microsoft via this website, because they have been able to reproduce the same crash with the same faulting module with the native Microsoft RDP (mstsc.exe)
https://partnersupport.microsoft.com/en-us/par_clientsol/forum/par_win/rdp-in-1709-crashes-connecting-to-any-windows-rdp/3b01a1a8-0063-4fa4-bf36-e7ae4b53f0d1?auth=1
The fix is available here - https://support.microsoft.com/en-us/help/4051963/windows-10-update-kb4051963
I would also like to know if you encounter the same issue using mstsc.exe?
I've been using mstsc.exe without issue.
That fix is not applicable due to it being a cumulative update for 1709.
Cheers,
John
Could you try to rollback to the previous version which was 32bit. I suspect that RDM 4.6 64bit is causing the issue.
I have the same issues with RDM 32 and 64 bit and have s support ticket opened ~
Since windows 10 1803 it seems:
Faulting application name: RemoteDesktopManager64.exe, version: 13.5.8.0, time stamp: 0x5aeb0399
Faulting process id: 0x2878
Faulting application start time: 0x01d3ff5da2ff428e
Faulting application path: D:\Apps\Devolutions\Remote Desktop Manager\RemoteDesktopManager64.exe
Report Id: c12c45ec-481b-4b44-b33c-6deee296ffd4
@Everyone,
After some researches, it looks like the issue is with DirectX, but I cannot confirm this behavior though.
Could some of you can try the solutions proposed below;
Let me know how that works.
Closed
