Personal credentials on ssh connection with ssh gateway (jumphost) not obeyed
When I use "custom" credentials it works automatically to login (but here my credentials are 'shared')
When I use same credentials in Personal credentials the username and password sequence prompt follows.
What could be wrong?
We are investigating in this area but for a support case with private key authentication. we will ask someone to test your scenario as well.
What version are you running?
best regards,
Maurice
Runnig version 13.5.8.0
Aha... just found this bug as well. Custom credentials works fine, but personal credentials don't. I get asked for a username when connecting.
I'm also using private key authentication - my personal credentials only have a username specified, not a password. - If I enter that username when prompted, it works fine. I'd rather not be prompted.
13.6.7.0.
